i sometimes have to deal with broken files that cause programs to hang and for some reason, the xp pro pc i'm stuck with has a few odd (and very annoying) quirks relating to the task manager:
first of all, it cannot close hanging programs immediately; ending a nonresponding program can take anywhere from 30-45 seconds.
secondly, if the pc is being thrashed (most likely due to swapping files out of the hdd into ram, thanks to a firefox memory leak), the task manager will not automatically appear when ctrl alt del is pressed -and sometimes it doesn't even appear at all, thus forcing a reboot.
thirdly, the task manager can become hung/frozen when trying to close hanging/frozen programs (!!!)
is there any way to fix this behavior or to force xp to end a frozen program?
thanks for reading!
system:
cpu: p4 northwood 2.53 ghz
mobo: compaq 07e8h
ram: 2x 512mb pc3200
thanks for reading!
system:
mobo: compaq 07e8h
