Target: Xbox 360 Wired controller $19.99 (Windows compatible)
Just got back from Target, and they had Xbox 360 wired controllers on clearance, for $19.99. This is YMMV, of course, but I've heard from other friends online that their respective Targets had it as well for this price.
This is the wired controller, which works with Windows (was the reason I picked mine up).
this is a great deal, although my local targets dont have it in stock and are selling for 27.xx. amazon has it for 27 right now which is also a good deal.
$20 is a great deal if you don't have one for your computer already.
$19.99 at the Target in Alexandria, VA - Potomac Yards Store. I'd expect them to be at this price at the Kingstowne & Skyline stores as well.
IDK if this controller is actually PC compatible. Usually the box says XBOX 360 Wired controller for Windows. This one does not, it only says "Made for XBOX".
i see the wireless ones on sale all the time at various sites.
I have thought of picking one up for my PC, however i have read that the wireless ones only come with controller and not the transmitter, which would be required for a pc.
I have never seen a transmitter for sale at the same sites.
What kind of transmitter is required?
Will a simple bluetooth dongle work? are these 360 controllers even bluetooth?
Darn, I picked one up when I picked up GTAIV for the PC. These don't come with the PC dongle though so your still gonna have to shell out for that, on the bright side I have seen some good deals for the wireless controller with the dongle on Amazon.
?? Dongle? Doesn't the standard, wired Xbox 360 controller use a standard USB connection? If so, no dongle needed, just the drivers from the net (for some OS'). Or are you referring to the wireless controller, you didn't really specify.
i miss read, I thought it said wireless controller.
EDIT: Nvmd, I didn't miss read. People went off topic on wireless controllers.
OT: I was really happy to have one of these when I had started playing TrackMania United Forever. Helluvalot easier to play with a 360 controller than a keyboard.
This one says it on the back, upper right hand corner "Works with Vista"
I've been using mine to play Braid via Steam, works great.
All 360 wired controllers work with Windows (its USB and says on the back works with Vista), its just the wireless that you need a special dongle.
it was 27 in AZ. But I picked one up anyways because you can never have to many usb controllers and I have need for wireless controllers.
You're right. I checked the box of the one I picked up. The itty bitty fine print on the back says 'works with XP and Vista'. IDK why MS wasn't obvious about saying "It works with PC's."
Because it lets them create a new SKU and sell the same thing for $10 more.
i dont think you can buy a wireless "windows" version without the adapter... thats why they cost more. its actually better now this way because the adapters went for $20 before, it seems that only the bundles are being sold now we see a drop in overall cost.
i think youre talking about the wired ones though.. obviously. i didnt know those came in different versions.
... Huh? They have a "PC version" of both controllers. Thankfully they started selling the wireless one with the adapter though.
