Tall desktop 40"+ TV mount?
AMD_Gamer
I am thinking about buying a 42-55" TV and would like to place is above my dual monitor PC setup. I would like to try an avoid doing a wall mount so I was wondering if there is such thing as a tall desktop mount that would be tall enough to reach up over my 24" PC monitors and have enough room for a large HDTV? Does such a thing exist?
If you want to mount it over existing monitors you're stuck with a wall mount for a monitor that large. Its just too big.
This is the nearest thing. Dual monitor vertical pole 28" tall. The claim of 45lbs per monitor is the impressive bit. Only problem is with one bracket at the top of 28" you get maybe 15" of space between the desk and the bottom of a 43" screen depending on how much space is between the bottom of the visible screen and the housing. You could probably get a 24" monitor under it, but imho it would be to low for ergonomics.
I actually intend on getting this mount and putting a single 43" monitor on it just for the height range available but will not have it too far up the pole.
