Well I've been quite happy with this build and I'm going to cut some holes for better airflow and whatnot. I would also like to redo the wiring job I did when I first set it up. Problem is I can't get the back panel off. All it does is bend. Should it come off? I've popped the front panel off and have unscrewed what looked to be the only thing holding it in place but it wouldn't budge.
Any clues as how to get this stuborn back panel off?
