Taking a stab at a decent entry system.. critique?
sanitystealer
Hey
I'm currently deployed as a contractor with the army in Afghanistan, and I'm set to finish up this coming March. At that time, I'll be building a new desktop - and I'm really wanting to put a half decent sound system together for it.
I've been reading a ton of recommendations and questions threads, and based on what I've read I've tried to take a stab at what I think might be decent. I know this is dangerous to say, but I have no hard budget - what I'm really looking to do is get the best entry level bang for my buck, wherever that value lies. The only piece of existing equipment I'd like to work in is my Senn HD595's.
Without any further adieu, here's what I'm thinking..
Topping TP D2 DAC/Headphone Amp: 140$
http://www.ebay.com/itm/Topping-TP-..._Audio_Amplifiers_Preamps&hash=item1c1e7cbbde
WHARFEDALE DIAMOND 10.2 bookshelf speakers (or something similar used): 300$
http://app.audiogon.com/listings/mo...-new-2012-11-08-speakers-80021-westminster-co
Dayton APA150 Amp: 130$
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-812
Dayton Sub-1200: 120$
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
Total: 690$
Anywhere you guys think you can consolidate, get cheaper components, or generally improve would be greatly appreciated. Thanks much for your help in advance.
I've been doing a bit more looking around, and I've decided to go the receiver route.
I've also figured I might grab some different components. This is what I'm thinking now..
Harman Kardon HK 3490 2 Channel 120 Watt Receiver: ~200$ used
http://www.ebay.com/itm/Harman-Kard..._Audio_Amplifiers_Preamps&hash=item4abe02679d
Klipsch Reference RW-12d 12" Powered Subwoofer: 300$ New (on sale, is this a good price?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078&Tpk=rw-12d
Polk Audio Monitor40 Series II: 120$ New
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
Or
Energy C-3 Monitors: 200$ Used
http://app.audiogon.com/listings/monitors-energy-c-3-monitor-speaker-2012-11-06-speakers-80227
Or
The Wharfedale Bookshelfs above..
I plan on connecting through the optical out on the mobo. Does this all look compatible? Is it balanced well? I'm concerned that the receiver or the sub might be overkill for those sets of speakers.. I'd sure like to save money anywhere I can if there's a less expensive option that doesn't compromise too much quality. I've got a few months to bargain hunt, my biggest problem is that I don't really know what good value is.
Any input is greatly appreciated.
