Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I bought Tagan (480W) when they first appeared here in the UK after reading some reviews.
That unit seemed ok, but I have since had a 530W 2Force and 3 x 530W EasyCon units, and everyone was problematic. The first 3 died, and the last replacement had a bad connection in the power cable from the wall into the PSU...........if I nudged the plug in the PSU it just shut down.
They look nice, inside and out, but the ones I had, although quiet (either the 2 x 80mm push/pull, or the 120mm versions) ran hot.
I also got BSOD's and game crashes which was annoying.
I personally would not buy another one, and have since switched to the Corsair HX620, and have not suffered any of the above irritations.
See here a review by JonnyGuru on the 530W EasyCon unit....http://www.jonnyguru.com/review_details.php?id=18
Your money, your choice....
