T260HD VS. Hannspree 28
Inverted08
Hey,
so basically, im trying to decide between these monitors, anyone have any ideas as to which one? mainly gaming, then web surfing, then movie
Thanks
The Hannspree at Bestbuy here in the USA I saw side by side with the T260HD, model with the 289 in it I think, looked way better as far as viewing angles... go check it out yourself, it's unbelievable they were both TN panels.
Wow i never knew they sold Hannspree in the USA, I thought it was only available in Europe. Do they make IPS panel monitors?
I went to best buy also, as far as viewing angles, i couldnt care less, however im really looking for picture quality and color. Because they didnt allow me to test the screens, i could not really tell which one was better
I just bought a Samsun SyncMaster T260 and so far I'm not impressed . It has lower half backlight bleed thats pretty overbearing, the blueish hue is present no matter what reasonable settings I use , the stand shakes CONSTANTLY very annoying when its the brightest object in the room and no 1:1 pixel maping ( on the non-HD version) which I didn't realize at the time I bought it. I'm gonna be taking this back next week when I have more money to buy the viewsonic 28 inch LCD (which is the same panel as the hanns) so if color accurate picture is a big concern avoid this one.
Checked out Samsung T60 No Vesa Mount is possible. Got the Hannspree HF289H, size matters. Had the Hannspree for 3 months and am satisfied though I paid $529 plus tax. No backlight bleeding, no dead or stuck pixels. Clear Fonts and even brightness of colors across the screen. Unlike some monitors with a darker side or uneven parts in the panel. When I use polarized sunglasses to check this out, some parts actually blank out. The advantage to getting the Hannspree is the 2 HDMI inputs. Support is easy to reach. Switches of the OSD are easy to get used to and work well. The Viewsonic is more $ and only one HDMI input and more comaparable to the Hanns G.
ahh ok, thank you for the insight, i saw online that hannspree came out with a hg289, which is supposed to have a substancial better quality than the 281
