T240HD Resolution Problem
Flatline09
Ok this is what I ran into.... Here is my specs with Monitor asset...
Monitor
Model name............... SyncMaster
Manufacturer............. Samsung
Plug and Play ID......... SAM03F0
Serial number............ HVLQC00112
Manufacture date......... 2008, ISO week 50
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 470 x 300 mm (22.0 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... Mstar 0x1400
Firmware revision........ 0.1
Firmware flags........... 0x1
Active power on time..... Not supported
Current frequency........ 65.54kHz, 0.00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-81kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1680x1050p at 60Hz (16:10)
Modeline............... "1680x1050" 146.250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1680 x 1050p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
Report information
Date generated........... 5/19/2009
Software revision........ 2.30.0.797
Operating system......... 6.0.6001.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,F0,03,34,32,44,54,32 ,12,01,03,80,2F,1E,78,2A,EE,91,A3,54,4C,99,26,
0F,50,54,BF,EF,80,B3,00,81,80,81,40,71,4F,01,01,01 ,01,01,01,01,01,21,39,90,30,62,1A,27,40,68,B0,
36,00,B1,0F,11,00,00,1C,00,00,00,FD,00,38,4B,1E,51 ,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,
79,6E,63,4D,61,73,74,65,72,0A,20,20,00,00,00,FF,00 ,48,56,4C,51,43,30,30,31,31,32,0A,20,20,00,3C
Now here is the same Monitor from a friend of mine!
Monitor
Plug and Play ID......... SAM0425
Serial number............ HVYS######
Manufacture date......... 2009, ISO week 6
Screen size.............. 520 x 320 mm (24.0 in)
Video bandwidth.......... 170MHz
Native/preferred timing.. 1920x1200p at 60Hz (16:10)
Modeline............... "1920x1200" 154.000 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync
1600 x 1200p at 60Hz - VESA STD
Report information
Date generated........... 4/2/2009
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,25,04,34,32,44,54,06 ,13,01,03,80,34,20,78,2A,EE,91,A3,54,4C,99,26,
0F,50,54,BF,EF,80,A9,40,81,80,81,40,71,4F,01,01,01 ,01,01,01,01,01,28,3C,80,A0,70,B0,23,40,30,20,
36,00,06,44,21,00,00,1A,00,00,00,FD,00,38,4B,1E,51 ,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,
79,6E,63,4D,61,73,74,65,72,0A,20,20,00,00,00,FF,00 ,48,56,59,53,32,30,30,39,36,35,0A,20,20,00,0A
PROBLEM!!!!
Plug and Play ID's Don't match mine is SAM03F0 his is SAM0425 .... its telling me that its a 22' NOT 24'. It is an EDID issue which means the manufacture who put in the EDID's messed up.
Now to show how I got all this information download this:http://www.entechtaiwan.com/util/moninfo.shtm
Also Read this forum as some other people are having the same problem http://forums.slickdeals.net/showt [...] 65&page=18 Start at page 18 and onwards.
Now is there any where I can actually figure out to change the EDID or somehow change this so that it supports my 24' in T240HD monitor?
