T1 installation
day1yun
I have a general question about t1 installation. I know a t1 uses 24 analog phone lines for data and voice and depending on the type, it uses them differently. Assuming its a pri t1 with 23 available lines and 1 being used as a control line, how it is wired? A cable goes into a csu/dsu wan port in a router? Then from the router to a firewall or a switch? Does the router need more than 1 wan port? Thanks
As far as I know you're looking at 24 channels, not 24 analog phone lines. Same as how a 56k leased line is far different from a 56k modem.
Normally you'll have the T1 come into a smartjack provided by the LEC. From the smartjack comes basically a network cable, I believe it's actually RJ48X. There will be a short cable coming from the smartjack which will terminate in a loopback box. You plug a network cable into the loopback box and run from there to either your CSU/DSU or a WIC1DSU (Cisco) in your router. That's all that is required WAN side.
cb9fl has it right, I would just add that it uses a 4 pair cable (Cat5, 5e, etc.) between the smartjack and CPE...
Think of it like cable TV. One physical cable, but many "channels". You can use each channel independently (i.e., twenty-four 64k digital phone/data lines) or combine them together to make one larger pipe of 1.5 megabit/sec.
