T.V. Tuners...Full Screen
Michigan PC
if you install a tv tuner, can you view tv programs in full screen with no black bars or media player crap?
What if you want the black bars? I am considering the nextvision n5 and want to know if on my widescreen monitor if I can actually get a 1:1 image rather than a stretched one
Hi Michigan!
I have WinFast 2000 xp Expert.
The software which comes with the card supports scaling:
Force Ratio 4:3
Force Ratio 16:9
If you untick the one thats selected, it will scale to the entire screen
Tho the software doesn't support PAL60hz, which is unfortunate for me since I live in a PAL zone.
DScaler is another option. ( http://deinterlace.sourceforge.net/ )
This downloadable tv card application is full of options to play with.
This also allows 16:9(letterboxed or anamorphic), 4:3 or take up full screen.
It also doesn't have wierd white bars at the top of the screen like I get with the PVR software.
Attempted Photos (I did NOT change aspect of game)):
PVR 4:3 / 16:9 / Full
DScaler 4:3 / 16:9 / Full
Image Captured from DScaler (NTSC / PAL 60hz)
Image Captured from PVR (PAL50hz) (same image as what you see in photos)
Brightness settings are available (overlay etc)
Image Captured from PVR (PAL50hz) (darker)
