T Line placement.
Igg
Based on this pic, where would you guys place a t line for filling?
The exos fill port is a pain to use.
The easiest place would probably be right before the pump so that water immediately gets sent around the loop.
Hm, the only place to do that is behind the exos but as you see the line drops down, i wonder what happen if i place it on the inlet of side of the exos...
the inlet side sounds like a good plan. it goes pump -> res inside, right?
The inlet goes from back of exos to radiator then res/pump
my fear is that since the intake is veritcal, the water would drop down instead of going side ways in.
this is true. possible to put it between the pump and rad, or is it too much work? :p
even if i splice the line, the res would still be at the top of the fill line, looks like im screwed eitherway
I might have to adapt some kind of extra pipe that goes INTO the exos fill screw then extend it up , basically making the res bigger, but that would look ghetto as hell.
No room :(
Plus my gf has a tendency to step on my computer parts, that and dust too.
