T-bred B ??????
digiram
How do you know if you have a t-bred b or just a regular t-bred?
Will vendors advertize the chip as a t-bred b, or do you have to just get lucky?
any thing would be helpful
Are you talking about Barton cores?
Bartons have 512k L2 cache and are marked as Bartons.
T-breds have 256k L2 cache and are marked as T-breds.
no where in hist post does he hint towards info about barton cores
t-bred a's were made using the .18-micron process
t-bred b's were made using the .13-micron process
usually online retailers such as zipzoomfly and newegg specify the core.
as for steppings..
AIUGA: TBredA
AIUGB: TBredB
if you post this in the strictly amd section you will probably get a lot more replies, but i believe hi tech hate is pretty much dead on
as for steppings..
AIUGA: TBredA
AIUGB: TBredB
uhhh, wrong...ALL Tbreds A or B are on the .13 process...Palomino was on the older process...as far as reading the steppings that looks correct
mines a mad oc'r, if i got it wet, i could probably get it to 2500 at least, but that money that could water cool is going for a shuttle case.... now i'll have to put my clock back down :eek:
