Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey, quick question, can the T-Balancer bigNG be connected to a Flowmeter out of the box, or is the Sensorhub needed? The site is quite confusing I found, or maybe that's just me.
You need the add-on analog sensor hub, which will accomodate 2 flowmeters. I use two T-balancers each with the analog hub so i can monitor all 3 loops with flowmeters.
