The only things wrong with that image are that I don't see the Folding at Home processesHupo said:Is there any processes here that long wrong? Ty
http://img.photobucket.com/albums/v357/Hupo/Computer probs/untitled.jpg
Oh thanks alot!!!!!! I've always wondered about this too! this clarifies things better nowExcavator said:jpmkm - Oops, is that better? Edited it a bit.
And yes, it means your system is 98% unoccupied.
And in 10 seconds of total time, you could have googled "System Idle Process" and had your answer. One would think having the name of "Idle" it would have been easy to figure out. Oh, Microsoft, and your silly wordplay!MaXimus666 said:Oh thanks alot!!!!!! I've always wondered about this too! this clarifies things better now
WTF kind of site is thatChingChang said:The only things wrong with that image are that I don't see the Folding at Home processes
As previously said, the System Idle Process just shows what percent of the CPU is NOT in use. It's nothing to worry about. If you open up a program or something, that program will use CPU cycles, and the System Idle Process will go down depending on how many cycles are needed for the program you just opened.
But that screen shot shows 4% CPU usage at the bottom, but only 2% is shown in the processes... if it were 4% it should show 96% for System Idle Process.. dunno why
(if you are interested in folding though - http://folding.stanford.edu or check out the Distributed Computing section of these forums )
Jerkdjnes said:And in 10 seconds of total time, you could have googled "System Idle Process" and had your answer. One would think having the name of "Idle" it would have been easy to figure out. Oh, Microsoft, and your silly wordplay!
As the saying goes....common sense isn't always common.Hupo said:Jerk
I must be missing something... I get the folding homepage. What was I supposed to see?Hupo said:
jpmkm said:I must be missing something... I get the folding homepage. What was I supposed to see?
I understand that; I think you've missed what I was trying to say. Hupo sounds like he is getting something other than the folding homepage.jonw757 said:Meaning he isnt using any cpu power and to start folding to do something good with it
Because a number of windows services use the svchost executable with various switches.Hupo said:why am i getting so much svchost for ??
