R1ckCa1n said:I don't think Sharka is done with their banner add either........
We all know the results anyways!![]()
vindication of the sort that A-C outperforms aftermarket air and Tt gear while overclocked, or that it can put up results that legitimately compete with what bit bore equipment can do if you cut the flow in half?Top Nurse said:Yeah I know...but having it all in writing will make me feel good. Vindication is like =>![]()
DFI Daishi said:vindication of the sort that A-C outperforms aftermarket air and Tt gear while overclocked, or that it can put up results that legitimately compete with what bit bore equipment can do if you cut the flow in half?
i don't much like crows.......even if some hippie witch wannabes call them ravens and try to feed and foster them around here. so far as i'm concerned they're vermin who don't know anything about anything and live in a fansasy world.......theseeker said:Which part of the crow do you prefer? Or should I say crows?
DFI Daishi said:i don't much like crows.......even if some hippie witch wannabes call them ravens and try to feed and foster them around here. so far as i'm concerned they're vermin who don't know anything about anything and live in a fansasy world.......
oh, i'm not going to try and spell out parallels just yet..........i have just finished up with all of my seminars, lab exams and papers, so i'm in a good mood right now......
just you wait until i hit fiinals.......then we'll all see some acid.
venom, then?theseeker said:Dashi,
Dont do acid, that is so sixtyish!
okay.....now i'm honestly curious: is this yet another expression that i am totally unfamiliar with? (see: "scoots")Top Nurse said:Well...I suppose we will just have to wait to see who eats crow. Me thinks you will no matter what the results of the review turn out to be.![]()
DFI Daishi said:okay.....now i'm honestly curious: is this yet another expression that i am totally unfamiliar with? (see: "scoots")
in all seriousness, i expect A-C to split the gap between what good aftermarket air and what well planned high flow can do.
you say that the O-C performance gap between A-C and big bore is so small that it doesn't matter.
i say that if you're going to take that stance regarding A-C vs big bore, you should stick to aftermarket air, since it costs less, looks better and A-C only outperforms good air by a similar margin.
yeah, the review is going to show SOMETHING........i'm just wondering how it was conducted, and if they will make it readily comperable with what domestic bits can do.
Top Nurse said:So...with what is left it should be obvious that all things being equal you either choose a highg flow or low flow system based on what you figure to be the best looking for you. IMHO, Aqua Computer gear is the best looking stuff on the planet. Why do you think so many cases are sold with windows on them.........
Erasmus354 said:So it would appear evident that reasons TO buy AC are very superficial, whereas the reasons not to buy are a bit more concrete.
darkisz said:I realized this about 2 years ago, but man, has it been fun watching all you guys 'discuss' how AC compares to every other w/c config on the planet. Very entertaining!
How great do they look after the mixed metals start corroding eachother?phide said:I for one feel that AC makes some great looking products,
Top Nurse said:"scoots" are those things that help you scoot through life. Prominent examples are cash, gold, silver, big credit line, etc. They can also be things you hold of value like cars, boats, airplanes, and even AC gear.
I think that what will come of this review is that people will know that they can get one block (Cuplex XT) and by using various tubing sizes can get predictably consistent results that will run as good as the best of them. No need to put anything bigger than a 3/8" ID tube to get what you want and that the difference in using a 6mm ID tubing is minimal for the intended usage.
Let's face facts here, most people only watercool so they can say that they are watercooling. Most people OC the crap out of their boxes to see what it will do and then set it at some reasonable OC, while it is watercooled, so that the dang thing lasts a while due to the better cooling it receives. So...with what is left it should be obvious that all things being equal you either choose a highg flow or low flow system based on what you figure to be the best looking for you. IMHO, Aqua Computer gear is the best looking stuff on the planet. Why do you think so many cases are sold with windows on them.........
madmat said:I dunno where you were raised but where I grew up scoots were either Hogs or a case of the trots.
Personally I think dragging out this review like this is pretty unprofessional, if it's done put it up unless there's an issue. If I can work sick the webmaster can sit at his PC an put up a review. He's most likely whiling away his time surfing for pr0n anyways.
Top Nurse said:Southern California...the land of the BIG scoots.
Personally I think it has something to do with Sharka and their timing.
thewhiteguy said:How great do they look after the mixed metals start corroding eachother?
madmat said:I'm from Modesto and Stockton. I'm sure you've heard of at least one of those. Up there those are known as Perks.
Why would Sharka have anything to do with holding up the review? They dragging their feet going over it?
theseeker said:You repeat this statement over and over. You must know something that some of us do not know.
phide said:I do find it interesting that they manufacture a mix of copper and aluminum components when they know and understand the associated risks. You've seen nikhsub's acetal (Delrin) AquaTube clone, Nurse. Would you or other AquaComputer users still opt for an anodized aluminum AquaTube when given an option to use a risk-eliminating acetal or clear acrylic variant?
We all take risks when taking the plunge, but why take risks that are unnesessary once we reach that point?
theseeker: i have linked you to articles on this subject before. google galvanic corrosion. it's real and it's a concern at room temperatures when metals have a fluid bridge between them and a path to ground.theseeker said:I am still waiting for someone to post the definitive article on why we shouldnt mix metals. I cant wait.
BTW, how do you feel about copper and silver?
phide said:I'd be happy to dig up a few links for you later tonight. Galvanic corrosion should be a very serious concern to anyone who places galvanically dissimilar metals in fluid contact with one another.
Concerning silver and copper, they're galvanically similar enough (close enough on the Anodic index) to not be a cause for concern. I take the relatively slight risk because of the minute benefits of running a coolant with a greater heat capacity and more ideal viscosity (something I deem fairly performance for ideal performance with the Storm G5). I've also seen no articles concerning the length of time copper would take to significantly corrode silver when both are submerged in water, so I don't personally feel it's anything to be concerned with. I'll also note that, as an enthusiast and budding block designer, I understand and accept the potential risks of running silver and copper in the same loop and do my best to minimize them. The typical end-user may not have any idea what galvanic corrosion is or what it can do, and I don't believe AC goes to any length to inform anyone of potential risks.
In a typical environment, a difference of .25V in the Anodic index is tolerable. The difference between copper and pure silver is roughly .2V. The difference between un-treated aluminum and copper can be as high as .6V.
This issue really depends on the anodization AC is doing with their aluminum products. This may be something you could answer for me.
R1ckCa1n said:corrosion typically occurs when you mix the metals and they touch....... Other than the Aquagraphics with a copper core (not recommended by AC), I don't see a problem.
I too have been running AC loops for over a year and have had less a corrosion problem than I did with my Dangercrap, Swifcheap, and Dtek blocks.
theseeker said:It may come as a surprise, but Ferrari, Aston-Martin and Porsche all have mixed metals in their cooling cycle in their cars. Corrosion can be controlled by chemicals/additives or whatever you wish to call them.
taqueso said:Over at procooling, they are recommending 10-12% zerex solution for preventing corrosion in loops with aluminum and copper.
No snappy name for Dtek?R1ckCa1n said:Dangercrap, Swifcheap, and Dtek blocks.
thewhiteguy said:No snappy name for Dtek?![]()
To them I am the trollErasmus354 said:If you just ignore the trolls they go away eventually.
madmat said:Here's what happens after 6mo.s of 90/10 (Water/Zerex) water and coolant mix with a bimetal block.
<pic that makes me cry>
I think I wouldn't follow their advice.
