I recently got this bootup error on my SATA internal drive. I could not get to windows.
I then took my IDE internal HDD from my enclosure that still has XP on it and hooked it inside my PC and made it the priority for startup.
I can get into XP on my old HDD and my SATA HDD with the corrupted file(s) can be accessed still because I can view it in My Computer.
My question is, can I manually drag and drop files on my SATA HDD windows xp pro install instead of going through some repair sequence?
Can I drop the files listed on http://support.microsoft.com/kb/307545
Looks like I am just replacing files under /repair to files under /config
What I want to do is, while under windows with my working hdd, drop said files and replace corrupted/missing files on my non working hdd and then take out the working hdd, and boot up like I normally would with just the one SATA HDD.
