Jimmy the Greek
- Aug 20, 2002
I'm trying to set up a RAID1 on a eVGA 680i board, and have to use the SATA RAID driver disk when installing XP (yes, I could slipstream the disc, but want to use that as a last resort.)
The cable's twist is on the end that goes into the FDD, and the drives' lights only go on when they're actually reading the disks. However, I've tried three different drives, and none is able to read the data. I used one of these drives last week with my IP35 Pro and didn't experience any problems, and doubt that it died in that time.
Is this motherboard known to have issues reading from floppies? Could it be anything other than a motherboard problem?
BTW, the A Drive and FDD Controller are both enabled in the BIOS.
