Hello,
We have here an Asus P4P800 with a 2.4GHZ Pentium 4, 4x512MB Corsair DDR-400 RAM, a BFG 6800GT AGP Video card, and an Antec 430w TruePower. All these parts are ca. 2003.
Yesterday, the machine worked fine. We moved it to a different room, set it up, and now it won't POST, though all devices appear to be powered. In particular, we get no video at all, and it does not attempt to boot Windows (no disk activity if we leave the disk plugged in).
Here are the configurations we've tried and the result:
- Mobo + CPU + Power = 1 long + 2 short beeps
- Mobo + CPU + Power + Video = 1 long + 2 short beeps
- Mobo + CPU + Power + Video + 1 stick of RAM = No beeps
- Mobo + CPU + Power + 1 stick of RAM = No beeps
This is an AMI BIOS, and the 1 long + 2 short beep suggests a video card problem (provided this is accurate: http://www.bioscentral.com/beepcodes/amibeep.htm). I'm not 100% sure this mobo uses an AMI BIOS as I don't remember, but other posts on the Internet suggests it is. I had upgraded the BIOS in the past to a fairly recent version--much newer than the stock version. This system has no history of instability and worked fine until we moved it.
Other steps we've taken:
- We've tried several RAM configurations, different slots, different sticks, etc, but the result is the same in each case according to the above table.
- Cleared CMOS by removing the battery and fiddling with the jumper.
- Checked various cables, e.g. ATX power cable, to ensure all pins are making contact.
- Checked power supply voltages with a voltmeter with the video card and RAM in to ensure they were reasonable. We read 12V on the yellow lines and 5V on the red (relative to ground).
- No bulging capacitors, smoke, or scorch marks
About the only thing we've not tried is removing the motherboard from the case, but this seems like such a long shot at this point.
My guess is either the video card or motherboard with a smaller chance of power supply problems, but I'm interested in hearing your input as to any other things we could try. We don't have a spare video card or the capacity to test the card we have, so that's still a variable. We will likely buy a cheap AGP card to test unless anyone has any other suggestions.
Thanks for any help.
