System won't boot after moving to a different case
speedfrk
Actually, I can't even get it to indicate that it is getting power. It was running perfect until now... AMD 939 3800 x2 on a Soltek K8Tpro. It was using an Enlight 420W PS and after I moved everything, I don't even get an led lighting up on the board. So I tried an older 300W Enlight PS and got the same thing. So I had one more old PS on the shelf, a 300W Antec and it tries- it will light the led and try to spin up the cpu fan for a second and then it beeps and quits. Then it does the same thing over and over again but never gets past that. It almost seems like the board is overloading the PS and it shuts down and then tries again and again. This is all before you even try the power button, so it is not trying to boot. Any ideas? I doubt that all 3 PS are bad, in fact the 420 was working fine in it right until I took the system apart to move everything. Possibly a dead MB?
How is it setup right now? Fully loaded config? Try a barebones (1 stick ram, mobo, vc & PS) and see if it boots up then. Also check all your case mounting screws.
Otherwise I would pull it and do a bench test and see if you can rule some of the things out 100%.
Try the setup outside the case.
I'm about to do this... I put it back in the old case and still had the same problem. The more I think about it and the way the PS acts, the more it seems like there is a grounding problem.
Well, I plugged everything up out of the case and there is no difference. I'm guessing the MB is dead. Strange since it was working perfectly and suffered no damage when it was moved.
I did notice that when I plug the PS cord in the back, there is a barely perceptible blink or dimming of the light in the room which makes me think that something is trying to draw a lot of power. Do the PS have protection circuits built in that would keep it from powering up the board if it sensed very high current draw?
Update... I tried the original PS in another computer and it works fine, so my conclusion is that the board is dead. Everything looks good- no leaking or bulging caps, no obvious burn marks, etc. Oh well.
Instead of trying to find another 939 board, I think I will just sell off the processor, video card and memory. 939 boards are getting very hard to find and this system is getting pretty old.
