System will not POST with DVD-RW installed
MrMike
This is the first time I have ever been completely and utterly stumped on a hardware problem and it is probably a silly oversight which I normally notice when I sit back from the situation, but I still haven't figured it out.
Hopefully someone here will have a suggestion. My home server in my signature , Zeus, does not completely post when the NEC DVD-RW is installed in it. What exactly happens, is it goes through the initial POST screen of detecting the drives fine, then the BIOS for my HPT2220 loads, then the Intel Boot Agent for the gigabit NIC, and normally after this there is the good old text style screen of the specifications of the system, and then it attempts to boot to the boot devices in order. Instead, it goes to a blinking cursor in the upper left hand corner and just hangs.
I am plugging it into the secondary IDE channel on the motherboard. I have tried two different IDE cables, both plugs on the IDE cables with the drive in all cable select, master, and slave. All twelve combinations. I have tried a hard drive on this chain as well without issue. I have not tried the DVD-RW on the primary IDE channel. I have tried the DVD-RW in another computer and it works.
Thanks in advance for any replies.
