System Upgrade
Dan_D
Cat Can't Scratch It
Well I've got a couple grand laying around and I was thinking about upgrading my system. Before I start. No I will not buy an AMD processor. It's nothing against AMD specifically more the motherboards and chipsets for them.
I want PCI-Express which rules out AMD for the moment anyway. I know theres no real bennifit to DDR 2 and PCI-Express right now. But I am future proofing the system for a little while at least.
Heres my choices.
Xeon (Nocona) 3.0GHz 800MHz FSB CPU=$373
Supermicro X6DAE-G2 Dual Nocona Xeon Board=$531
1024MB ECC (Registered) DDR2 533=$400ish
Total=$1304 (Single CPU)
Total=$1677 (Dual CPU)
Other Choice
Pentium 4 550 3.4GHz LGA775 Prescott 1MB L2 Cache, Hyperthreading Retail=$425
ASUS P5AD2 Premium=$300
1024MB DDR2 533=$400
Total=$1125
The prices are only approximate. I didn't necessarily pick the lowest prices I could find. But I just wanted rough figures to work with. Now I am leaning twords the Xeon rig because I want to PCI-Express 16x slots for the Geforce 6800 Ultra SLI setup. Also the Nocona Xeon system has the potential to have a second CPU if I choose or I could get them both. Next the Xeon also has EMT64 technology. Not a big deal yet, but might be at some point. Theres some future proofing there as EMT64 will be used one day.
Although I may not use EMT64 ever it's a possibility since when I upgrade again I'll likely use this rig as a server or something.
I also do some video encoding as well as gaming. So the Xeon fits the bill there. Plus I don't have to deal with crappy LGA775 pin breakage.
So anyway dispite the high cost I am leaning twords the Xeon. Unless anyone knows of a LGA775 board on the horizon with dual PCI-Express 16x slots. In which case the Pentium 4 would make the better choice for a gaming PC with some video encoding use.
Xeon Pros:
SMP Capable
Dual PCI-Express 16X sockets for future use of Dual Geforce 6800's.
EMT64
As an alternative I could spend the money I was going to spend on the second CPU on getting a higher speed single Xeon.
Xeon Cons:
Higher cost
Needs registered ram
EMT64 may never really take hold but it's likely it will someday.
Pentium 4 LGA775 Pros:
Faster CPU speed than single Uni-processor 3.0GHz Xeon Nacona
Cheaper motherboard and overall solution.
Cheaper upgrade path
Doesn't need registered ram
Pentium 4 LGA775 Cons:
Crappy socket design (possible breakage)
No option currently for Dual PCI-Express sockets, so getting a dual 6800 SLI setup will require a new motherboard again.
Thoughts are always appreciated. My system is decent and I may decide to do something else with the cash. But I thought I'd see. Maybe theres some Pro's and Con's I missed.
Oh, DUAL. Never mind, I was about to have to call you an idiot for picking Pentium over Athlon64.
I say Xeon just for badass factor. Dual processors extends the useful lifetime of a computer (assuming you can keep the auxiliary hardware up to date as well) by so much it's ridiculous. A Quad PPro 200MHz box is still a usable machine. A P!!! 500MHz box is slow.
It means something.
Go Xeon.
Yeah, I'd choose the dually too. Just be careful what ram you choose. Most supermicro server boards are very picky about ram.
Well on one site they recommended Samsung registered DDR 2 ram. Which is also Intel approved.
