I just built a new system with a passively cooled xfx geforce 7950gt and the system temp is running at 41C even before I attempt any overclocking at all. (The C2D E6300 is at 45C)
I have a rosewill case with 120mm fan intake and 120mm out the back and it has a circular tube for the filtered side vent over the cpu and a normal vent near the video card heat sinks.
The power supply also has two fans; one sucking in air near the cpu/rear fan.
The motherboard is a MSI P965 platinum and the northbridge heatsink is right between the cpu and video card heatsinks(it wraps around the card.)
So, I guess my question is how hot is it ok to let system temp get? And is it crazy to modestly overclock a system with a passively cooled, hot video card like this? (my goal was high performance and low noise without going crazy on cost.
