System shuts off... HELP
Acidwarp01
6 months ago I built a box just for surfing the net and doing word processing. All of a sudden about a month ago I left the system on and came back and it was off. So I turned it back on and it was fine... 2 weeks later I got up one morning, turned it on, saw the POST, and went to get coffee, came back and the system was off... Pushed the button and nothing happened! I unplug and plug it back in but nothing... plugged it into different outlets, different power stips, eventually it turned back on, ran fine for about another week, and then off it went.. Eventually turning back on... There has been no hardware changes since the day it was built... When the system is on it is running great.. the temp sits between 43 and 48C.Only reason I dont think it is overheating is sometimes it can be on for days and then no issue and then that one time the system had been off for probably 12 hrs... came on, but then shut off.. I assume a power supply issue... maybe... Any ideas? Just looking for some guidance on where to start... Thanks in advance for any help..
