System Shuts Down after POST
Bman088
I just built my new computer last night, and it won't work. I have an Intel D915PBL mobo with the Pentium 4 550 processor. I also have 1gb of kingston hyperx ddr2, 2sata hds, audigy 2 ZS, dvd burner, cd burner, and some extra fans. I put this up to let you know how much power i'm consuming.
THe problem is, sometimes when I turn on the machine, an alarm beeps at me with 2 tones, one high, one low. I think this means memory error, but if my memory was bad (it's brand new), wouldn't it do it everytime i turn on the machine. Once i get past the memory error (about every time), the computer posts, and i see the mobo screen that's right before windows, then it just shuts off. I have no clue what's wrong. Any ideas?
the beeps sound like a memory problem. However, the shutoff thing sounds like overheating. Are you sure you have your heatsink installed properly. Go into your BIOS during boot and check your CPU temps.
Re-seating the memory wouldn't hurt, too. Whenever I build a new machine I always install the memory, remove it, and install it again.-Just because I've had to re-seat it enough times on a new machine that I just do it from the start now. lol
What video card are you using? Not that it matters, I'm just curious.
Sounds like a heat issue, maybe you forget the TIM?
Re-seat the memory, that pretty always solves memory errors like that I get, RAMs a weird thing somtimes. :p
But yeah, a shut off like that is most likely a heat issue.
another thing - make sure your CPU fan is connected to the header labeled CPU fan. that may not be related, but just check - some mobos will shut down unless they read a fan on that header.
yeah, i got it working. It was a stock intel heatsink, it allready had some tim on it, but i added some arctic silver 2 to it. Now it finally works. It runs at around 200 farenheit when in the bios, is this ok? I'll post my other question i have, cuz now my HD won't recognize...
Ummmmm, 200F? That's 100C.
Okay, pop that heatsink back off. Take some alcohol and remove both. Now, reapply the AS2.
If you dont do this soon dont be surprised if you fry the chip and possibly your mobo....
I remounted it. I hope that the bios is just reporting my temps improperly. Cuz i put my hand in the case, and it reported my system temp at being above 100 degreees farhenheit, and i know that isn't true. so i dunno. I hope i don't fry my system, that would be unfortunate.
*edit*
It says, Processor zone temp: 96C/204F System Zone 1 :38C/100F System Zone 2: 38C/100F Processor Fan Speed: 2448 RPM Front Fan: 0 +1.5Vin 1.493 Vccp: 1.317 +3.3Vin 3.310 +5Vin 5.157 +12Vin 11.562 is all this norma?
I think maybe "Processor Zone Temp" means the max operable temperature that you can sustain and not have the computer shut down; in this case 96C/204F refers to the limit.
What follows are the actual temps in your case and your processor, which is apparently measured by built-in thermistors on your board, or something similar. So maybe System Zone 1 is the built in socket thermistor and Zone 2 is the cpu on-die thermistor.
This is all just postulation and i've probably got a couple major facts wrong, but that's my thought on it.
