Xcom_Cheetah
- Apr 12, 2002
In last 3 months, my 3 power supplies have died... and the new one which i have bought (its a generic no name power supply) is also causing trouble... I have a feeling that my motherboard is the culprit...
It is happening that my system restart between 1 to 30 minutes... and sometime when i power on the system it start giving a beep like there is no RAM in the system. Sometime it just get held when i try to login to my account... I mean there r all sorts of problem with this system.. i have just changed the RAM to kingston 2 x 512 MB.. i have changed the power supply and i have also changed the BIOS battery but to no avail...
Any suggestion..?
i just checked the power variables in the BIOS and it was showing 2.92 - 2.96 V for 3.3 cable.. and 11.0 - 11.2 V for -12V cable... isn;t it too much difference.?
or can this be due to the RAM... RAM is also getting over heated.. but the system temperature was well inside the limit around 30 C and processor temeperature around 48 C...
Any help will be appreciated.
Thanks
Any suggestion..?
Thanks
