System reboots on memtest86
bgates2b
I've run memtest 86 on several machines as a diagnostic tool.
I'm running it on a Dell Optiplex GX1 w/ a PII 400 and 128MB of PC-100. The owner complains that the system will reboot when starting Internet explorer (runs WinXP).
I made a bootable memtest86 v. 3.1 and the test runs with no errors until it gets to around 82% done with the tests, when the system will reboot.
I never had that happen during memtest before, I would at least see some error codes. Does this mean the memory is bad?
Well, I just re-ran it for the 4th time and it completed this time with no errors and no re-boots. Not sure what it is.
Thanks OldMX
Damn Dell PSU.....how do I test these since they are wired differently?
Try google. There are some sites that show how to mod Dell PSU to work with a standard ATX plug.
Any suggestions?
MBM doesn't work on this board and there is no voltage option in the bios.
