System purchase advice needed
dpaul01
After way too much reading of this board and others, I've decided on the following components, with intent to OC and move to SLI eventually. Any advice or changes would would be appreciated. I have to say, if you had only one board to read, this would be the one by far.
http://www.newegg.com/Product/Product.asp?Item=N82E16817703001
PC Power and Cooling 510 SLI
http://www.newegg.com/Product/Product.asp?Item=N82E16819103584
Opteron 175
http://www.newegg.com/Product/Product.asp?Item=N82E16814130279
eVGA 7900GTX
http://www.newegg.com/Product/Product.asp?Item=N82E16811163037
Silverstone TJ05S...btw Monarch has this for 135..I bought it there.
http://www.newegg.com/Product/Product.asp?Item=N82E16822136012
Raptor 150
http://www.newegg.com/Product/Product.asp?Item=N82E16813130037
K8N Diamond My current 754 is the MSI Neo, and its very stable, which is important to me. This mb has had good reviews, Oc's well and has 16x PCI-e SLI. It also has more room for SLI.
http://www.newegg.com/Product/Product.asp?Item=N82E16820227225
OCZ OCZ5002048EBPE-K 2GB Kit DDR500 PC4000 Platinum
Yes, I know about the g.skill on sale for $144 at newegg and almost decided on them. For another $140 at this point, I don't care. Xtreme, Anand and others rate this memory very well.
