TeleFragger
- Nov 10, 2005
Ok so I have built the rig in my sig at the bottom... (except that 2x2gb more is in the mail
Went to bed at 1am with the machine up and running...
woke up at 5am and machine was off..
turned it on and installed COD4 while I went to work..
got to work and game installed.... using RDP was installing some other apps but then realized my machine was no longer on... called the wife and she said yes it is off... she turned it on and she went out... I was doing some stuff here and there when I get time as yes I am working...
so at 11:30am (lunchtime) I figured id go and check out a few things... well it is off again....
now I had an issue with the ocz reaper 2x2gb kit... 1 of them kept on bluescreening the machine.... during boot... so I figured out which of the 2 it was.....
I remember being in the bios and everything was set to auto for cpu and memory...
well that would be 1.87v for memory...
while a guy and I were specing out a machine for him... we saw my memory and he said... Boy I dont understand this voltage stuff but your memory is running at 2.2v and this other memory is 1.8v...
It then hit me.... oh geez... is that why the memory is not working right in the system?
so BSOD caused by incorrect (too low of voltage?)
also the memory is supposed to be 5-5-5-18 but in the bios I remember seeing 6-6-6-18 on auto...
am I now at the point where I need to set all this stuff and not let the mobo use auto?
so I need to set my memory to 2.2v and also set 5-5-5 too????
would that also cause random shutdowns?
Thanks guys...
Jeff....
Thanks guys...
Jeff....
