I just built a new computer and I have been overclocking it over the past few days. Everything was running stable and then two days ago I was using a currency charting program and I got a BSOD that displayed for maybe a second and then the computer immediately restarted. At first I thought it was the software, which has some cpu intensive indicators running but nothing that should even come close to stressing a Q6600.
The problem is, the BSODs happen randomly. I started running stress tests trying to cause another BSOD so that I could take a picture to read what it said (the error message displays for less than a second before the computer restarts) but it wouldn't work. I was running two instances of SuperPI 32M, doing Prime95 blend tests, stressing my GPU (ATITools & 3dMark) but they all passed just fine. There was one time where it gave me a BSOD during tests but I don't think it had anything to do with the stress tests running because I ran them again and everything ran fine.
I initially thought it was my memory (G.Skill PC-8000 4GB), which is clocked at 800Mhz (under its rated speed) with rather tight timings (4-4-3-12) and a voltage of 2.0. Thing is, I ran as many stress tests as I could for it and they all passed. I ran MemTest86+ through the boot cd (passed test #5 15 times with no errors), then ran HCI MemTest through windows and then two instances of SuperPi 32M. Also did 1hr30min of blend through Prime95 and an hour long OCCT stress test.
Now I am kind of thinking it might be the video card. I installed an Accelero S1 and I think some of the thermal compound got smeared cause the heatsink kept on shifting while I was trying to line up the screw holes.
I also have a ThermalRight HR-05 installed on my northbridge, which was also a tricky install because of the piece of shit mounting bracket they give you. I thought maybe it wasn't installed right and the northbridge is overheating.
Just now, I opened up my computer to replace one of the fans and connect an internal card reader. Right after windows loaded and installed the drivers, I opened up CPUID to check my temps and got another BSOD. Then after it restarted, I got my camera all set up and tried running some stuff to stress it cause i figured it was getting worse and would happen pretty quickly but got nothing.
Usually when you get a BSOD, it just stays there on the screen. So I am wondering what could be failing that would cause the computer to restart right away. I'm sure one of you has some ideas.
I wish I had a picture to post but because its so erratic and only lasts for a second, I can never catch it.
System:
Intel Q6600 G0 Stepping (lapped TRUE)
Gigabyte DS3L
G.Skill PC-8000 4GB
eVGA 8800GT
WD 320GB
Asus DVD-R
Corsair HX520
System:
Gigabyte DS3L
G.Skill PC-8000 4GB
eVGA 8800GT
WD 320GB
Asus DVD-R
Corsair HX520
