System panel connections on Wavemaster?
FusionXP
For the life of me I can't find any info on what wire color is positive, negative or ground for the RESET SW, POWER SW, H.D.D LED and Speaker. I know where to attach them on the mobo but in what direction? For example, should the blue wire be connected to the PWR pin or Ground pin on the power switch?
This is what the Wavemaster case has:
Blue/White - Power Switch
Orange/White - H.D.D LED
Grey/Grey - Reset Switch
Red/Black - Speaker
The power and reset should work either way, the red is the positive on the speaker leads, and for the hdd activity and power leds just hook them up, if they don't light up reverse them.
