Alright. I bought an Opteron 170 used. Pretty decent stepping. The previous owner seemed to have some success overclocking it (stable 2.8 GHz @ 1.425v, tested 2.95 GHz @ 1.525v), but now I'm working on overclocking it. I'm on water, and here's my results so far (using Orthos to test):
2.60 GHz @ 1.35v - 4 hours (I stopped it)
2.65 GHz @ 1.375v - 9 hours (I stopped it)
2.7 GHz @ 1.45v - Dunno, my computer turned itself off last night... Re-running now.
And now, the WTF:
2.8 GHz will not boot at any less than about 1.55 volts. And even then, the SECOND core is only stable for about 3 minutes TOPS. At the same volts as 2.7, it lasts about 3 seconds.
I'm on water, and my full load (Orthos) temps never go above ~45-50 degrees for the core (in SpeedFan; my Rad fan is at 50% due to noise so that's why the temps are high like that) even at that setting. So what gives? Any advice? My RAM is not the problem it's set at an obsenely low divider AND I only run the "Small FTT" tests.
Specs are in the sig.
And now, the WTF:
