I've been using MSI Afterburner for overclocking, fan speeds and looking at stats on my GPUs. Up until recently I was using a Logitech G15, and made use of the plugin for the LCD. Now I've switched keyboards and have been using Afterburner's On Screen Display for the following numbers:
FPS
GPU1: Temp, Fan Speed%, Usage%, Core/Memory Clocks
It has been infinitely helpful while figuring out my first CrossFireX setup and generally helpful when overclocking and checking temps.
Now I'm looking to add CPU statistics to that OSD. Come to find out Afterburner won't do that for me!
I installed Rivatuner, but I couldn't figure out the GUI for the life of me.
So, can [H] give me some programs to look at to fill my needs?
I really want to keep all the info I have with Afterburner's OSD, but having a single program to do everything would probably be simpler. I'm open to either option!
FPS
