Ok, I put together a system and now it keeps shutting down on me after being up for less than a minute. The specs are:
Asus A7V8X-MX SE
Athlon XP 2600+
512MB PC2700 DDR
ATI Radeon 9600
I had this same problem a couple months ago when I first put it together, but I got a new cpu and that fixed it. Now, just a couple weeks ago I decided to swap the cpu with my main system, but realized that my main pc only has a 266 FSB. I took the cpu out of this system and put the older one in it so it didn't get damaged, but I never turned it on. After I realized that I couldn't do what I wanted I put the 2600 back in and when I turned it on, it started doing the same thing of shutting off after less than a minute. It also powers on for a second then powers off then back on when you first turn it on. I had this system going with windows installed and let it run for hours with no trouble, but I'm stumped now. Could it be some kind of a heatsink issue with the COP feature Asus puts in the BIOS? I bumped it up the the 95 degree setting, but that didn't make any difference. The CPU shouldn't have been damaged by putting it in an A7V266. Anyone have any ideas?
Asus A7V8X-MX SE
Athlon XP 2600+
512MB PC2700 DDR
ATI Radeon 9600
