I upgraded my computer last month in preparation for Battlefield 3. My system is listed below, with the smaller/darker text describing old/removed components.
The Problem
Recently I've had some sound issues in Teamspeak. When not in-game, I sound fine to everyone, with some very faint buzzing/humming in the background. However, when I go into a game (single player or multiplayer, and which game doesn't matter), the buzzing/humming becomes quite loud. Everyone sounds fine to me regardless of what I'm doing. Bear in mind that everything had sounded fine for weeks, then one day, buzzing sounds. I had installed no new software, nor changed the hardware or drivers between the day when I sounded fine and when I didn't. Nothing new had been plugged into that electrical circuit, anywhere in the computer room, or even in the entire house. Nothing had been unplugged, and no cables had been moved. Since the problem developed, I've checked all cable connections.
After uninstalling/reinstalling sound drivers (the latest from Gigabyte's website), trying different headsets, and rolling back my system to an earlier restore point, I'm at a loss as to what could be causing it. I can only assume some piece of hardware is being stressed while in-game. Perhaps it's the on-board sound going bad after working fine for a few weeks. Perhaps my video card is giving off EMI when stressed, and is getting ready to go. However, this has been a real puzzler to me, and when weird issues pop up that are difficult to pin down, I start to suspect the power supply. Having one guy in my clan eventually say the noise, "sounds like my power supply did when it was starting to go." just pushed me further in that direction.
So, if someone disagrees with the theory that it's my power supply, I'm ready to listen to alternatives. Short of that, I'm thinking of picking up this replacement:
Antec EA-650 Green
http://www.amazon.com/Antec-EA-650-Green-Energy-Certified/dp/B004NBZAES/ref=pd_sxp_f_pt
Opinions? I know there are some that would rather I pick up something closer to the $150 range, but after my other upgrades, money is short. Not as in, "I won't be able to buy 2 Starbucks every day.", I mean really short.
Future Upgrades
In the near future, I will be picking up a new hard drive - probably another Western Digital Black in the 500-750 GB range. Also, I hope to be replacing my GTS 250 with a new sound card. Eventually, i will likely add another 2 sticks of the same RAM I listed above, for a total of four sticks and 8 GB. That's it.
MY CURRENT SYSTEM & HARDWARE said:Windows 7 Pro - 64-bit
four sticks of RAM of currently unknown name/spec, for a total of six GB
Two sticks of Corsair Vengeance 2 GB PC3-12800 1600mHz (PC3 12800) 240-Pin DDR3 SDRAM 1.5v Dual Channel (four GB total)
Intel Core 2 DUO E4500 Allendale, 2.2 Ghz
Intel i5-2500K 3.3 Ghz
Gigabyte GA-P35-S3G motherboard
GIGABYTE GA-Z68P-DS3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s ATX Motherboard
Realtek ALC889 on-board sound
Nvidia GTS 250
250 Gig IDE HD (retired due to age/incompatibility)
500 Gig WD Black HD
Pioneer DRV-215D DVD drive
ASUS VH236H Black 23" 2ms LCD Monitor (1920 x 1080)
19" Dell CRT
KINGWIN ABT-450MM 450W - 3.5 years old
The Problem
Antec EA-650 Green
Future Upgrades
