ASUS P5K Deluxe
8800GTS640MB (old one)
Ballistix 2gb
Lite on DVDRW
Seasonic S12 550W
C2Duo e6420 (that was running overclocked at 3.2 stable for the first 6-8 months of its life)
Windows Vista Ultimate
The system was stable for 6-8 months. Then I was having stability problems and I had to replace my GSkill memory that getting memory test errors in memtest. This happened again a few weeks later and was replaced with the current ballistix which doesnt have any memory test errors.
I continue to have random blue screens though and they are really unpredictable and I am getting different IRQ Fault errors and Page Fault errors each time it seems. Most recently yesterday my computer blue screened while I was using it, I manually restart and it continues to blue screen every time it trys to boot into vista with different system files missing each time. Classpnp.sys one time , ntfs.sys another etc. I have had other strange power issues as well where I would come back and the system would appear to be in sleep mode but would not come back and I have also come back to see my system locked up at the Asus splash screen at startup with weird visual artifacting although that has not happened recently.
Note that this is a fresh install of vista, I recently reformatted on a new hard drive but I have the old drive hooked up to pull data off of.
I have replaced the motherboard on rma, replaced the powersupply on rma. Unless this memory was somehow tainted by the old motherboard it is also new. I think it could only be the videocard or cpu causing problems at this point. I think I will replace my videocard on RMA next and if that does not work then I will buy a new cpu. Its all I can think of to do at this point.
Thanks for any input.
Ballistix 2gb
Lite on DVDRW
Seasonic S12 550W
