System Instability
Gollum0000
Specs:
Gigabyte K8NSNXP-939
AMD Ahtlon 64 FX-53
Kingmax 2x512MB PC3200
BFG geforce 6800 GT
Maxtor 40 GB HD (1 partition) and 120 GB HD (2 partitions) (not using SATA)
The computer is crashing/restarting a lot. Usually happens when I am playing a game. The system will just crash to the desktop. Occasionally it will restart. I honestly do not think this is an overheating issue. Was wondering if anyone else has had problems with gigabyte mobos. Any suggestions would be great, thanks. I do keep up with the latest drivers/bios as well. I dont have the latest bios, but I have one from late last year. Ran memtest and the RAM passed.
Are you overclocking your videocard?
Watch the cards temps... it could be overheating...
Have you tried switching out for another video card?
Weak power supply? Make sure that the voltage stays within limits when you're stressing out the system...
been a while since I posted. I was having a bunch of problems with certain parts in the system so here are some new specs.
Gigabyte K8NSNXP-939 (RMAd the old one, this is new)
AMD Athlon 64 FX-53
Corsair 2x1024MB C2 PC3200
BFG 6800GT
40 gig HD and 120 gig HD (both maxtor) using IDE
Also got a new p/s. Antec 500W Smartpower 2.0
So, I still have problems in games. System will restart randomly. There is artifacting occasionally. Sometimes the system will restart even in windows. Sometimes it restarts WHILE its restarting. So unstable its rediculous. I cant even imagine what the problem could be. Think its a voltage issue? Im not overclocking at all.
Just to give some more information, when the Windows Loading screen appears, I can hear a constant hissing coming from the computer. Its not present when the computer is starting up, only when the load screen starts, and then it stays until I shut down. Its really annoying and Im pretty sure its not a fan, Ive tried playing with the fans but none of it make sthe sound go away.
Anyhelp for any of these problems would be greatly appreciated. Ive tried a bunch of different driver versions for BIOS/GFX card/Chipset/other devices with no luck.
if it was me--i would check the temps on the NB. it may be overheating on the nb causing a crash :eek:
Hissing sound? Leaky cap? Overloaded coil?
With the computer on place one end of a cardboard paper towel core over your ear, and place the other end around the board, cards, and drive(s) until you locate the area of the hiss. Then inspect for damage, or things that are touching that shouldn't be.
Look for grounding on the back of the board in case a screw fell back there.
Cant even get into windows anymore. Also when POSTing it takes a while for the HDs to be detected. Cant get into safe mode eihter. I would check the NB temp but I cant find it in the bios and hte program I use to monitor the temps w/ this mobo I need windows for. I have an extra 80 GB HD im going to test out on here tomorrow.
I know CPU temps is like 45
GFX card around 65.
Ill post again after trying out the new HD.
Wow, i had some similar probs, but w/ ASUS's newest MB, but it was while using BIOS 0201, sometimes it would take a very long time for the Hard Drives to be detected, other times, it would just freeze at "Detecting USB..." etc.
Now, that I've moved up to BIOS 0311, that problem has stopped, BUT, now, I frequently can't log off, restart or shutdownt, windows will just stay there, so I have to hit the reset button.
And also, I have system freezes, once a day usually...but it never BSOD'd, or restarted, but while it was frozen, the HD light would stay lit.
Mmm...while I am using a different MB, I thought u'd just like to know u're not alone.
Popped in a new HD. Fresh installed of WinXP Pro. The Hissing sound I was talking about I did not hear. And no freezes so far. (Im going to test World of Warcraft which is guaranteed to crash within 20 minutes if the computer is still not working).
So I DL the latest nvidia drivers after the fresh install of winxp. Install and as the install finishes, the hissing sound comes back. Wierd....
Anyways, ill post back when I find out if there is still instability after playing WoW.
Just to conclude this post (for others who have a similar problem and may stumble on it), it seems to have been the Hard Drive or the way it was configured. The system runs perfectly now. Also downloaded IDE drivers for my chipset which helped too.
