System instability
Koreanzulu
I managed to overclock my e6400 with biostar 965pt to 333x8. My fsb:ram ratio is 1:1 using 533 Memory speed. My voltage is at stock and i'm having some trouble. When i boot my computer and get into windows my computer restarts with a lot of HD activitiy. Or i'll be doing something and my mouse and keyboard will freeze with my speakers buzzing. Are there some settings i need to tweak. My computer is only at 44c load at 333x8 and i feel this shouldn't be my max.
This may be the blind leading the blind...but at 333 what is your FSB running at? Wouldn't your memory be running overclocked unless you set a lower ratio or is this completely separate from the FSB?
Good luck!
