System instability / crashing, need help
jkrafcik
I'm trying to debug a machine I built a year and a half ago and worked fine until very recently, and I'm running into some really strange problems.
First, my machine:
CPU: i5-2500k
Cooler: Scythe Mugen 2
Mobo: Asus P8P67m PRO B0 (currently on BIOS version 3602)
PSU: Antec NeoPower 650
Case: Antec Sonata Proto
RAM: 2x4GB G.Skill
Intel SSD (120GB)
Samsung HD (2TB)
My machine started to reboot periodically -- like once every 1-5 days. Generally while under no real load besides backing up online. I read through the event viewer logs, and I saw that one of my drives was timing out, so I thought this might be a BIOS issue. I flashed to BIOS version 3602 twice, got the system up and running again, and still noticed occasional reboots. I then reset all of my ASUS-derived OCs to run completely stock. That seemed to help, and I stopped seeing some minor graphics corruption I'd see occasionally, but then the crashes started the infrequent crashing started happening again.
Since I have a B0 P67 board, I was wondering if I had bad SATA2 connectors, so I moved my drives from the onboard SATA2 to SATA3 and my CDROM from SATA2 to the on-board Marvell controller SATA3.
This is when things got really crazy. I reboot, and I see errors for "CPU over temperature error!" and "CPU over voltage error!" I went into my BIOS, and the readings were totally bogus. 512F chip, 24V power rails. If I powered down and powered back up, the system wouldn't boot at all (no fans, no beeps, no lights) until I cleared CMOS. Once again I saw the temperature / voltage problems, I cleared BIOS, and I got into Windows. I saw that the drive problems were still happening so I upgraded my Intel Rapid Storage Technology driver. Rebooted, and the events went away.
Then while watching TV, I watched my machine reboot itself after ~13-15 min of idle time, about 4 times. I then played some Diablo 3, and it crashed in the middle. I tried to boot up in the morning today, and the fans wouldn't even so much as spin until I cleared CMOS. When I booted back up, I saw the same voltage errors. And when I saved BIOS and rebooted, I once again no longer POSTed until I reset CMOS. I've tried this about 5 times today, and each time I have to reset CMOS.
So right now, I unplugged all my SATA data and power connections, rebooted into the BIOS, and saw no cpu over temperature or over voltage errors. However, when I went into the BIOS my readings are totally wacky:
- CPU temperature fluctuates between N/A, 12C, and 106C
- Motherboard is either a reasonable 26C or N/A
- CPU voltage is 1.26V or 0.002V
- 3.3V is either 2V, 3.2V
- 5V is 5V or 0V
- 12V is 12V or 24V
- CPU_FAN, PWR_FAN, CHA_FAN1, and CHA_FAN2 are all jumping all over the place between actual values and "N/A"
One last thing -- when I unplug/plug my power cable into my PSU, I hear very faint snapping/cracking sounds that sound like there might be some arcing. I don't know if this has been happening for a while or if I just noticed it now.
In summary, I went from infrequent crashes to a dead machine. What do you think is wrong with my system? I'm guessing it's either the PSU, the mobo, or the CPU -- but I don't know which and I don't have spares for any but the PSU to switch out. Because of my huge ass HSF, if I want to replace the PSU I'll need to take out my entire motherboard....
Thanks for any help!
Those incorrect readings make me think that your motherboard is a culprit.
The P.S.U. thing seems to be scary...
Same symptoms here. Ever since updating to version 3602 my system has gone bananas. Tried the same stuff OP did. Any news on this? I am worried this could start affecting other system components!
