I hate Windows 8, let me get that out of the way. I decided to give it a try and it's on my HTPC at the moment.
Finally found the old Windows 7 backup program that was hidden in there and used it to create my backup and system image to a separate HDD. Win8 won't let me boot from that drive to access the image, so it makes me create a Repair Disc. I burned 8 different repair discs, different brands etc, and NONE of them will boot. Windows 8 says they were all created successfully, it lies apparently.
So I decided to see if I could just access the repair/restore options from the Win8 boot/install media and I could.
At that point I thought great, it works, but no... I get this error:
Windows cannot restore a system image to a computer that has different firmware. The system image was created on a computer using EFI and this computer is using BIOS.
I don't understand what's going on as it's THE SAME COMPUTER! I installed Win8 to the computer, created the image with the computer but yet it says I can't restore the image to that computer.
I created the image on this computer and I'm trying restore the image to THE SAME COMPUTER that created the image but it says I can't, I've been at this for at least 4 hours now trying to figure it out and I'm at the end of my patience...
All of my other computers run Win7, and they will all stay that way for a long time to come, but I want my HTPC to work and it won't...
Anyone help?
Anyone help?
