System hangs. Starting to get a bit frustrated
Ok here's the deal:
AMD X2 3800+
4GB Rosewill DDR 400 3-4-4-8 2T
eVGA NF41-SLI Mobo
eVGA 7900GTX EGS
Sonata II case w/450W Smartpower PSU
74GB Raptor (boot drive)
2x300GB Maxtor SATA drives (1.5, 16MB Cache)
60GB Hitachi 120GXP
160GB WD External HD
Pioneer DVD/RW
XP Pro SP2 - fully updated
Those are my specs at a glance, here's the problem. I just built the system about a month ago, been running great and stable. In the last couple of days the system now hangs any where from a few minutes to a few hours after a reboot. The system hangs so hard that I have to hit the reset button to reboot. I'm currently running Prime95x2 while I'm at work to see if it craps out or not by the time I get home.
I did have the system OCed for a while, the CPU from 2000 -> 2400 and the GPU from 650/1600 -> 690/1700. I ran 3dMark05/06 and both completed while OCed with flying colors.
I realize the two weak points in my system currently are:
The RAM, which is great at stock speeds but doesn't like to be OCed(in fact I chose 240x10 so that I could set the RAM at DDR400 speeds, but for some reason the RAM rolled back to DDR333 speeds at this OC).
The PSU which is sitting with 15A/18A on V1/V2 12V rails. This is soon to be remedied as my Fortron FSP 700W arrives tomorrow. I bought this because I'll be going SLI as soon as my eVGA stepup happens for my 7800GT.
I guess I just want advice/suggestions/insults about OCing with less than ideal parts...whatever it takes to keep this system stable.
And yes, all virus/spyware definitions are up to date and cleaned out, and this Windows install was brand new just a month ago.
So let me hear what the masses have to say.
Thanks!
Edit: Also wanted to state that the GPU hovers around 50 at idle and CPU is around 40 (this is with the AMD HSF).
When does it hang? Can you replicate the problem? Have you installed the fixes for dual core?
