init6
- Sep 26, 2002
My sig box is just shy of three months old. It's run like a champ since the day I built it, but yesterday it basically "crapped out" on me. I had it connected to an old BackUPS 500 I had, but it's a 580W PSU. Yesterday while I was using it the power to the whole house shut off and the machine immediately turned off. The UPS was beeping away but it didn't give my machine 1 second of uptime after power loss.
When the power finally came back on the machine worked fine. A little after midnight I had finished playing Battlefield2 for the night and decided to boot back into Linux, my primary OS, to finish tweaking the reinstall I had done earlier. After restarting Windows it hung.
The POST completes, I get a beep and then a buzz telling me the fan isn't working (standard). The fan then spins up and it continues the boot sequence. Now, however, it hangs at what appears to be the memory test. I'm looking at the BIOS logo and so forth, but it says "Memory Te" and hangs. Sometimes the HDD LED comes on, sometimes it doesn't. It always goes off eventually, but nothing ever happens.
If I leave the machine OFF for a few hours (1-2 hours doesn't do it, overnight did) I can turn it on and it'll boot right up. I had the great idea when I got up this morning that it was the UPS causing a problem! So while it was booting I shut it down (before I ever got to GRUB, much less started loading an OS), unplugged it from the UPS and back into a surge protector.
Fired it up and...nothing. I then began to unplug components until I had it down to the processor, video card and one stick of RAM. I removed my wireless NIC, unplugged the single IDE channel (connected to two optical drives) and both of my SATA HDDs. I removed both power and data connections for both optical and hard drives.
At this point I'm thinking it's the PSU. Sometimes when I give it power the LEDs glow dimly on my intake fan but it sits for 1-2 seconds before firing up and getting all the fans going (only two right now, one intake, one on the HSF).
I guess I could start fiddling around with a multimeter on the PSU, but is there a point? The fans (both) spin up on the PSU and I know it's giving power to the components when it actually boots up (because then everything works).
It's a 580W PSU with 2 x SATA HDDs, 2 x DVD burners and the two case fans, as well as a PCIe power connector to my videocard. Should that really be taxing a 580W PSU??
I'm at my wits' end, and could use some feedback before I RMA a PSU that might still be good. This box is critical to me and I need to get it running again. Two year old laptops just don't cut it.
