lzqtiancai
- Jan 21, 2011
Hi , I just upgraded my computer a week ago from c2q. now detailed spec is in my sig. BUT I ran into a problem. My brand new ssd - ocz vertex plus 2.5 sata2 120gb(my windows 7 64bit primary drive) keeps on getting corrupted?
symptoms.
1. C drive needed a consistency check during bootup(happened a couple times), errors were found and recovered.
2. In event viewer: "the file system on the disk is corrupt and unusable, please run chkdsk utility on the volume\device\harddiskVolume2." ( happened maybe 3-4 times)
3. In event viewer: "the file system on the disk is corrupt and unusable, please run chkdsk utility on the volume C:"(happened maybe 3-4 times)
4. restart, I ran Chkdsk utililty a couple times, both times fixed errors. bootup to windows the rerun disk eror check, everything s good, until maybe a day later. same errors pop up in event viewer.
5.side note: first I thought it was my ram, so I ran memtest86+, 1st pass, failed with quater million errors. pulled out test stick by stick on 1st slot, OK. pairs by pairs OK. slot pairs OK. put everything back: memtest overnight 6 passes: OK again.... Idk. its inconsistent...
6. side note: had random bsod 0x0124 and 0x01A, but havent seen it since the bios update
anyway, Do I have a bad ssd??? Thanks in advance
symptoms.
