System crashing while playing games, getting blue screens
Flogger23m
Hello everyone. I am having a lot of issues with my PC. They may or may not be related errors, but if you can help me with them, then please do so. Check specs at bottom of post.
I bought a new PC around 6 months ago, and it has been running 100% stable for around 4-5 months, but then I started to experience crashing and occasional blue screens in games. Since crashing ect. only occurred in games, I figured it was my video card, so I uninstalled my video drivers and ran Driver Sweeper, and installed Nvidia's 182.50 drivers. My issues went away for 2-3 weeks, but now I am getting them again.
My issues:
1) APC_index mismatch bluescreen
2) I have had an odd error happen to me twice. When I was playing games, my sound would go off and I would hear an awkward sound coming from the speakers. The odd thing is, when I played a video file, I could still hear the sound, but not from games unless I restarted.
The second time it happened, I got a blue screen before I could exit my game and restart it. I am not sure what the blue screen was and I didn't get to write it down.
I am using onboard/motherboard sound.
3) Games crashing and giving me the generic "program stopped responding" error. (most common).
4) When playing the game Red Orchestra, I get this error:
Build RedOrchestra_Build_[2005-11-27_10.48]
OS: Windows NT 6.0 (Build: 6001)
CPU: AuthenticAMD Unknown processor @ 2600 MHz with 4093MB RAM
Video: NVIDIA GeForce GTX 260 (8250)
General protection fault!
History: FDynamicActor::Update <- AActor::UpdateRenderData <- Kar98Attachment RO-Danzig.Kar98Attachment <- FDynamicActor::Render <- RenderLevel <- RO-Danzig.myLevel <- FLevelSceneNode::Render <- FPlayerSceneNode::Render <- UGameEngine::Draw <- UWindowsViewport::Repaint <- UWindowsClient::Tick <- ClientTick <- UGameEngine::Tick <- Level Danzig [Gdansk] – 28th March 1945 <- UpdateWorld <- MainLoop <- FMallocWindows::Free <- FMallocWindows::Realloc <- 4C576C61 0 FArray <- FArray::Realloc <- 0*2 <- FMallocWindows::Free
RO has always ran fine for me, and has always been stable even on my old PC. I am not sure why it is crashing now. I also have the game SWAT 4, which has always been giving me this error, even on my old PC (I tried SWAT 4 with 3 different video cards on my old PC, same error to). Both games use Unreal Engine 2.5. Any thoughts?
5) I can not seem to update my Framework Net 3.5. Service Pack 1 update (KB951847). Every time I try to updated it, it fails. I have tried this three times now.
What I have tried:
1) Scanned for Viruses and adaware/spyware with updated versions of AVG Free, Adaware Free, Super anti spyeware/adaware free. The worst things I kind are the occasional tracking cookies.
2) Scanned RAM with memtest twice. No errors are displayed.
3) Reseated RAM and put it in dual channel (oddly it was not in dual channel when I received the PC...)
4) Took out video card, reseated it and disconnected then reconnected the power cables for it. Have not got a bluescreen yet, but Red Orchestra still gets the error above.
Video card temps run around 78 degress C max. CPU runs around 59-60 max. Are these temps too hot?
My specs:
GTX 260 192 variant Superclocked by EVGA
Corsair XMS2 TWIN2x4096-6400c5 4GB
AMD Phenom X4 9950 Black Edition
ASUS M3N78 Pro ATX AM2+
Vista 64bit Home Premium SP1
Antec Sonata III Black ATX
Antec Earth watts 500 PSU
Samsung SH-223F/BEBN 22x Speedplus
Western Digital 1TB SATA 2 hard drive
PCI card with parallel port for old printer
Everything is stock, aside that I replaced my CPU's heatsink/fan with a Sunbeam 90mm. I have not over clocked anything.
I know a lot of people will say my PSU is not enough, but I have been told otherwise by people that work at computer building stores. My brother also has a very similar PC with the same PSU, but has three hard drives instead of one, plus an HD 4870 1GB. He is getting no such errors. I also have around 2-4 amps on the 12v rail to spare.
If someone could help with any of the errors, I would be thankful.
I'm guessing here, but can you swap the video card and see what happens? Nvidia GPUs have been having some manufacturing issues during the past year or so (hopefully they fixed it). It has affected mostly laptop users, but I'm sure the desktop GPUs are also affected.
You can also try running a Furmark benchmark/stress test to see what happens.
Are those benchmarks free to download?
Unfortunately I don't have a spare PCI-Express video card. :(
Furmark is free, right here http://www.ozone3d.net/benchmarks/fur/
I used it on my 4850 one time, because it was artifacting and crashing in games, and running this made the artifacts show up. Had to RMA the card, but it's working totally fine now.
Your brother has a 4870; can't he let you borrow it for a few hours to test it? :(
Ok, I tried Furmark (thanks for the link!). What exactly should I be looking for when running a stability test?
I ran it for around 140 seconds with no errors or artifacts, at 1680x1050 with FSAA at 8x.
It did get up to 80 degrees C, but I've never seen it go that high in a real game.
How long should I be letting it run?
Edit: Let it run for 273 seconds, same settings, no errors, and it got to 84 degrees C.
Ok, so I reran the test, but for 1030 seconds this time. Same settings as above, and my card went to 86 degrees C max. No artifacts or errors.
So I guess this rules out a video card hardware issue?
First thing to always check in this situation is the PSU. Or even just check to make sure all power connectors are snug. I once returned a video card to the store thinking it was bad and when the new card had the same issue I checked my power connectors to the mb and the main power connector was not pressed in snug and that's all the issue was, doh on me. I also spent almost a week once troubleshooting lockups and it turned out my brand new Enermax PSU was borderline. Put in new Antec PSU and was hunky dory again. Having good PSU is very improtant. Found a complete PC in the dumptster out back of my building one day so took it inside and swaped the PSU and it ran perfectly. Now use it as my Linux box. Thanks for the free PC whoever you are. :)
I reseated the video card as well as disconnected/reconnected the power, but I'll have a look in my case again.
Have another PSU you can try? Seeing as you are getting the BSOD I would seriously look at ram as the possible culprit too.
Aside from memtest, is there any way to check the RAM?
Don't have another PSU to try either. Except a 5 year old 350 watt, but I doubt that would cut it for my system.
There are other software ram testers. Vista has one built in. memtest is good though but you need to run it overnight so that it can thoroughly check it on mulitiple runs. Another way to test ram is to remove all sticks and put in one stick at a time until you find the bad stick.
As for PSU, it is always good to have a backup so consider buying a new PSU. You can also buy a PSU tester for about $20.00. if you don't want to pay for a new PSU. Newegg sells those.
