Was playing Left 4 Dead when keyboard (Apple keyboard) started randomly cutting out, then the sound began to go out. Then, the internet dropped (NIC went out possibly). Quit Left 4 Dead. Mouse started acting up. Checked system temps, all normal. All of a sudden, screen went black and system restarted. Using Windows 7 x64. Memtest+ 4 shows no RAM errors. System is stable while running IntelBurnTest.
I've only experienced this while playing Left 4 Dead (and it doesn't happen every time), Crysis Warhead doesn't do this.
Here's a dump of the crash that I extracted from the .dmp file.
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa80067d38f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_GenuineIntel
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`0335b6f0 fffff800`02d21a89 : fffffa80`067d38d0 fffffa80`05526680 00000000`0000000a 00000000`00000001 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`0335bc10 fffff800`02c03547 : fffffa80`067d38d0 fffff800`02c7c5f8 fffffa80`05526680 00000002`00000005 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`0335bc40 fffff800`02b6bb95 : fffff800`02cde360 fffffa80`0659c828 fffffa80`0659c820 fffffa80`05526680 : nt!WheapProcessWorkQueueItem+0x57
fffff880`0335bc80 fffff800`02ae6161 : fffff880`012abe00 fffff800`02b6bb70 fffffa80`05526680 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`0335bcb0 fffff800`02d7c166 : 167a167a`0b7e0b7e fffffa80`05526680 00000000`00000080 fffffa80`05508040 : nt!ExpWorkerThread+0x111
fffff880`0335bd40 fffff800`02ab7486 : fffff880`0316a180 fffffa80`05526680 fffff880`031750c0 143d143d`609d609d : nt!PspSystemThreadStartup+0x5a
fffff880`0335bd80 00000000`00000000 : fffff880`0335c000 fffff880`03356000 fffff880`035b7540 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: hardware
IMAGE_NAME: hardware
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_GenuineIntel_PROCESSOR_MAE_PRV
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
