system clock problem
Corson
recently i was ocing my mobo (nf7-s with a barton 2500) and i set it too high so my pc wouldnt boot... i reset the cmos so it booted up fine, but now my clock is wrong all the time, and my screen saver never turns on with the timer. i got a program that syncs the clock to the atomic clock but i wish i could fix it so i dont have to have that program running constantly, also, that program doesnt help the screensaver problem.
thanks
Well
When you reset the CMOS, you reset the time. How else do you think the computer keeps time?
Go into your bios and reset the time and then you can turn off the atomic sync app.
As for the screensaver thing, that may be a power management issue in yoru bios aswell, check the power management tab.
If not, just see if it goes away after setting time.
thanks, that did help. i just didnt realize that would do anything because the clock was semi-correct without having to reset it in the bios.
