System Building Help
w0lf42
Gaming / Web Browsing
$550 (including tax and shipping)
3) Where do you live?
Washington
Motherboard
CPU
Video Card
RAM
Power Supply
Case - Antec Sonata
Hard Drive (SATA - Sorry, building for a friend and don't know the model). I do plan on upgrading this when money is available.
Optical Drive (SATA - Sorry, building for a friend and don't know the model)
6) Will you be overclocking?
No
Plan to eventually get a 20" or 22" in the next few months
2-3 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0 / SATA 6Gb/s / Onboard sound / Onboard NIC
Win 7 Professional 64bit
Below is what I'm thinking of getting. Any Suggestions?
Motherboard
MSI 870A-G54
$100
CPU
AMD Phenom II X4 955 Black Edition
$140
RAM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
$100 = 2 x $50
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131374&Tpk=AX6850%201GBD5-DH
$155
Power Supply
OCZ Fatal1ty OCZ550FTY 550W
$50
Total Cost $545
Ditch that RAM: Since you're not overclocking, 1600 RAM will do nothing for you. Not to mention that you would have no room for RAM upgrades if you go for 4 sticks of RAM right off the bat. So go with this set of RAM instead:
$80 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
We generally don't factor in MIR around here as they're not guaranteed discounts. With that said, even if you do get the rebate, that OCZ PSU still isn't a good buy. So I recommend this PSU instead:
$65 - Antec Earthwatts EA650 Green 650W PSU
