last night my socket 939 k8n neo2 platinum had a very loud buzz and woke me up. i was too tired so i just shut the computer off and tried to figure out the problem today. banging the side of the computer helps for a few seconds but the loud buzz then continues. however, at times the buzz changes pitch and the corecenter reads that the system fan is at 0 rpms so I would shut it down immediately.
its not screwed down like the cpu fan, its two black tab things on both sides that can be pushed down. i tried to push them down simultaneusly but nothing happens. i dont want to yank them too hard off the motherboard if thats not what i'm supposed to do. i've tried using using air pressure to remove any dust but i've still got the same problem. any ideas on how to get the system fan removed/fixing the buzzing problem is appreciated. thanks
