thephatnessq3
- Feb 2, 2001
Hello all,
Even though this is offtopic since I'm not overclocking anything just yet I'd thought maybe you guys can help me stablize my system. Here are my specs:
Case: Lian Li PC-A05B (idle - 30c)
CPU: Q6600 G0 (idle - 35c, load - 50c)
Sink: Thermalright Ultra 120 Extreme
Mobo: Gigabyte P35-DS3R F11 bios
RAM: G.SKILL 2x 2GB DDR 1000 5-5-5-15
GPU: EVGA 9800GTX 675 MHz (idle - 60c, load - 70c)
Power: Corsair 520HX
Fans: CPU - 1x S-FLEX SFF21F, Case - 3x SY1225SL12M (all plugged into mobo)
DVD: Samsung SH-S203B
Sound: Auzen Prelude 7.1
HD: 1x Seagate 7200.11 500GB
OS: Win XP SP2
I'm experiencing random automatic hard reboots depending on the load. No BSODs or any event logs that can indicate any error. I have "Automatically Restart" on system failures turned off. Temps seem find to me.
Memtest86+, newsgroups downloading, bittorrent, etc. run with no errors and reboots. But 4 instances of Prime 95 will reboot it automatically within an hour. COD4 multiplayer or even Test Drive Unlimited will reboot randomly between 30 minutes and a few hours. And just for fun, running 4x Prime95 and a FFA COD4 game with HDTV playing on 2nd monitor will only last around 20 minutes.
So let me ask you guys where I should start tweaking. Most performance related settings in the bios are at default. Unfortunately I don't have a multimeter but everything I've read says that 520watts should be adequate for a typical build like this one.
Thanks...
OS: Win XP SP2
Thanks...
