Hi guys,
I have a bit of a dilemma i cannot work out.
I have a Corsair H100 Cooler with 4x Gentle Typhoon AP-15's.
Two of the fans plug into the SYS_FAN2 plug on motherboard using a 2 to 1 adapter.
The other two fans plug into SYS_FAN3 plug on mobo using a 2 to 1 adapter also.
Exact same fans, exact same cabling.
I noticed today that physically the amount of air being drawn out of the rad on one side is a decent amount lower than the other side.
Have found that the two fans plugged into SYS_FAN2 are running slower, actually at about half the RPM.
Here is what i see in bios fan section, and speedfan:
Please forgive my terrible photos i took them on my phone. Adjusting setting in bios nor speedfan does nothing to increase the speed of the fans plugged into SYS_FAN2, which i understand is as they are non PWM fans?
I am not sure what is going on, hoping someone who knows more than me on the subject can help me out.
Thank You for your time, and i hope i made sense..
EDIT: 150 views and no replies, either i made no sense, or my problem is too difficult for an answer, i am leaning towards the former...
