SYS_FAN and PWR _FAN
SAW
Howdy.....
What exactly plugs into these? Is it just a regular 3 pin fan?
What are they for?
Is the fan I will put for rear exhaust on the case the same as the SYS_FAN?
I have a place on my case for 3 fans. 2 in the front and one for the back. Where exactly do I plug in these 3 fans? Do I have to get a dongle (sp) that goes from a 3 pin connector to a 4 pin, bigger connector that plugs into one of the power cables for the PSU?
TIA for your replies :D
Hi,
What mobo & case exactly?
Sys_fan is system fan & is usually used for an exhaust or intake depending upon position of the header.
Pwr_fan I would imagine is for monitoring the rpm of the PSU fan but probably can drive a normal 3-pin fan.
The mobo is a Gigabyte GA-K8N Pro-SLI
The case is a simple plain jane black case, no name.
Also, the PWR_LED.......I cant seem to find this anywhere. On the mobo, its a 3 pin header, but I dont seem to have any wires/cables that go onto this header. The only thing "close" to it is this 4pin connector coming from the PSU. Its small, like a 3 pin connector would be, but its a 4 pin. Is this my PWR_LED? If so, what do I need to do to connect this to the mobo?
Rufus P Tumbeltin IV said:
The 4 pin from the psu is the floppy power conector, the power led is the green light on the front of the case.
Ok, so wont have to worry bout that 4 pin connector since I wont be using a floppy....
As for the PWR LED....I DO have those wires coming from the front of the case,,,and the ones that were labeled...such as the PWR_SW...IDE_HDD...RES_SW.....I have installed into the correct locations,,,,,however.....
There was another wire/wires coming from the front also....except these wires were/are set up differently...The wires (Green and White twisted around eachother) connect to a white connector with DIFFERENT hook ups than the above mentioned "light indicator" wires. This connector attaches to, what Im assuming is, a 4 pin Molex power adapter, which has both a male and female end. That connector is identical to the Molex adapters coming from the PSU.
So, what I "assumed" was that they (the makers of this case) made the PWR LED wire to connect straight to the PSU thru one of those MOLEX adapters instead of plugging it into the MOBO....
Is this a correct assumption?
Absolutely incorrect. :p The power LED will connect to the motherboard. It should connect in the same area that the power switch connected, on those little needle-looking connectors coming off the motherboard.
Well, as I said before.....the connetors are not the same....i.e. I cant plug the PWR LED into the mobo..
So, I did what I said a post or so above and guess what.....works like a charm :D
I now have my computer up and running and WOWWWWWWWWWW what a swwwwwwwweeeeeeet ride it is.....
on my case the power led plugs into a molex, because the power led happens to be about 4 leds and this thing that projects images/text onto the surface the case(gigabte aurora) is on. my last case, coolermaster wavemaster, the power led used a molex also. you are NOT absolutely incorrect.
sys_fan is just a 3 pin connector for any fan to plug into (that has a 3 pin connector) as is any other 3 pin fan connector on your mainboard. plug your fans in wherever you want, psu or mainboard, but some people think the mainboard will not be able to handle the big 8 to 15 watts the fans draw.
Now thats the info I was looking for, thanks dude!!!!
I dont have anything plugged into the sys_fan connector on the mobo, but I figured I "could" just plug in the fan for the exhaust fan on the rear of the case if I wanted to.
When I went into BIOS/PC Health, I can see the RPM's and temp readings for the CPU_fan, cause, heh, obviously, this particular fan is connected to the cpu_fan connector on the mobo. The sys_fan and LED_fan on the BIOS show zero. So, Ive drawn my own conclusion that THAT is why you would want to plug a fan into "those" particular connectors....so you can view how they are working thru BIOS. A buddy of mine told me this wasnt needed or required, its just a simple readout is all it is.
So, I just left those alone with nothing plugged into them, thinking, why bother the mobo with un-needed power drain when I can just simply use the PSU to power these fans.
I'll say again......WHAT A SWEET RIDE I HAVE BUILT!!!!!!!!
I think its time to put my specs into my signature :D.
For ALL of you guys who read MY thread here as well as others thruout [H] and are like how I was.."not sure you could build your own computer" All I can say is, heh, IF I CAN DO IT.....SO CAN YOU!!!!!
It is AMAZING just how EASY it actually was to do. Alot of us (me included) make it out to be much much harder than it really is. Reading thru the mobo manual...pulling out your hair wondering just WTF the manual is talkin about....PFfffffffffftttt. I look back to that now and, well....let me just say, just because the manual lists or talks about installing whatever, DOESNT mean you HAVE to use that particular thing or item. In fact, unless your REALLY going at it hard core and installing a shitload of components (which, if you are, you probably are not a newbie to building computers), its really VERY VERY VERY VERY SIMPLE...We make it harder in our minds than it really is. Just dont sweat it and get upset at something you dont understand, no matter how stupid you may find your question to be......just ask [H] and your GOLDEN....
Ive got to say, after I was completely done with my build....the feeling of accomplishment was OVERWHELMING and very very satisfiying. Only problem now is...I want to build another, hehe....
many times the manual is completely wrong, as in which dimm slots to use for dual channel, which jumper settings are default, etc. big ups for getting thru that successfully solo.
Thank Ya Sir.....Ill take that as a compliment :D
